wiring a CB **it's alive!!!**
Discussion in 'Communication (CB | GPS | HAM)' started by muddysub, Oct 28, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    wiring a CB **it\'s alive!!!**
    ok it says that i have to run the positive wire into the fuse box. do i really have to or could i just find any power source? it has an inline fuse so i would i think i'd be ok with any old power source. am i right?
    ok the fuse box is a mess of confusion for me (i'm electronically retarded) so what other constant power source could i tap into? and if i tap in to something else wouldn't it not get sufficient power to run both at once? (ex. KC lights and CB at the same time.)
    /forums/images/graemlins/ignore.gif all that above
    it's alive it's wired and running now i need an antenna and the wire for it! /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: wiring a CB
    yeah, you can splice into a power wire, its just easier to put a connector onto the end and plug it into a switched power plug on the fuse block.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: wiring a CB
    If you don't use your cig lighter, I'd tap into that for a power sorce.
  4. muddysub
    Jun 23, 2001
    10,452
    489
    Re: wiring a CB
    the lighter runs my KCs so i'll go to the fuse box.
  5. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Re: wiring a CB **it\'s alive!!!**
    GM was kind enough to leave a few open "hot" spots on the chevy fuse block. I just tapped into there for my stereo, KC switch power(not light power), and cb power. These are not fused connections, you will need to run inline fuses.
