Wiring a radar detector
Discussion in 'The Lounge' started by 90K5, Jul 14, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Got a radar detector from a friend a little while ago, and it actually works pretty good...I want to wire it up so I don't have to plug it into my light er though. anyone done this? Can I strip the end of the wire and plug it into the fuse block on a circuit that has power in ACC mode, like the one my CB is on? Will that work, or does it need a different source? What about plugging it into the lighter fuse? Will it be hot all the time or just when the key is in the ignition? Thanks
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I believe the cig. lighter will be hot all the time. I would hook it up with the cb since you know that is how you want it to come on.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    To be on the safe side, wire up another cig lighter plug. Some radar detectors are diff voltage and the plug is also a step down or step up transformer. It's real easy to wire up a second cig plug. I usely just tie them up under the dash out of sight. /forums/images/icons/grin.gif
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Where can you get another cig lighter plug?
  5. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    Call around your local auto supply stores and get a universal lighter plug, wire as you want and just plug the detector in and leave it. I would wire it so it turns off when I turn the key off.
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Wire it direct to a fused circuit that is on only when the truck is running................and ground the other wire to a good frame/chassis ground. Simple.
    This method keeps the wiring hidden. /forums/images/icons/cool.gif
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You can get them at almost parts store. I get them alot of time from junk yards. /forums/images/icons/tongue.gif
  8. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Radioshack
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think there is only one wire...looked at it yesterday and it seemes that way...we'll see
