Wiring a tach, 3 wire connection type, did a search
Discussion in 'The Garage' started by jjlaughner, May 22, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I have a factory tach (one like that going in the dash). I'm considering trying to install it.
    There is a red (12V), Black (ground) and brown (marked coil)
    Where on an 87 blazer with the remote coil can the tach's coil wire be installed? Can it be installed?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I believe it goes to the pos terminal on the coil... Not 100% on that.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the coil wire? if its hei, look at the distributor, and from the drivers side, there is a connector closest to the firewall, and forward of it (to the front of the truck) is a single wire, i believe if you splice into that single wire, you will have tach feed
  4. dyeager535
    26,982
    191
    Whats the coil look like where the plug goes into it?
    Is there another connector there with nothing on it? If so, thats the tach feed. White on my '88 TPI setup.
