wiring an 84 k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by paddyjim, Apr 21, 2001.
  1. paddyjim
    paddyjim Registered Member
    Mar 5, 2000
    8
    just a rookie looking for some advice from those of you who have probably done this a million times. the wiring in my 84 is all over the place. been cut out, spliced, etc. what a mess. I have been looking at the "painless wiring kits" and Ron Francis Wire Works kits to replace what i have. Which one in the better kit or is there something else out there that I should be looking at. Any suggestions would be greatly appreciated.
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    "Painless wiring kit" is the way to go. Time consuming, but they will send you instructions. Also kinda pricey IMHO.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I converted my 85 diesel CUCV to 89 TBI 350 which required a complete harness in the cab and under the hood (except for the light harness). The old harness was butchered to boot. I got mine complete from a junkyard and it was much cheaper than any of the aftermarket harnesses. If you were building some older vehicle, I would recommend the new harness. But with later model stuff (80+) you can still find good harnesses in junkyards easily and much cheaper.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  4. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    where do you get the painless wiring kit and how much?
  5. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  6. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I replaced my harness inside and out in my m1009 with a harness out of a salvage yard. Cost me 50 bucks for all of it.
    Scott
    78blazer
  7. dyeager535
    26,982
    191
    Use the factory wiring. Just try and get as close to your year as possible, and with the same options (PW, PDL) For instance I believe '84 was the first year of the headlight dimmer on the column, as well as the wiper controls, so the harness is a bit different than 81=83.
    In any case, with a Haynes manual, even if it is a few years too new, you can make the necessary changes. In actuality, very little changed.
    Dorian
