Wiring Diagram needed
Discussion in 'The Garage' started by Hossbaby50, Aug 2, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need the wiring diagram from an 85 K5. I specifically need the diagram of the wires to and from the ignition switch.
    What wires does the ignition switch turn on? Thanks
    Harley
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The ones I have in the tech forum don't have what you need?
  3. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    I have a factory service manuel but it no way to scan then load then send
    so what exactly is the problem
    It will help alll of us help you :-)
    (I .E.) the purple green and yellow wire is cut and i dont know were it goes
    OR ??????
    If i or nobody respondes here feel free to pm me
    and on that note BTT 4 ya:-)
    R
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Problem is my steering columns internals are FUBAR. I need to bypass the ignition switch so I can start my truck and get everything else to work too. (guages, accessories, radio, brakelights, etc) I need to know which wires I need to hotwire (and put on toggles) so I can get the things to work.
    MuddyTazz, I will have to look at the diagrams in the tech area. I wasn't aware they are there. Thanks
    Harley
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If your wiring is all good why not just replace the ignition switch? The turn signal wiring is separate of the ignition wiring. /forums/images/graemlins/thumb.gif
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The inside of the column is FUBAR. There is broken metal bars, broken plactic pieces, etc. It is way more hassle then it is worth to try and figure out how to rebuild it to work then just rewire it.
    Harley
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Ok, i follow you now. Your key will not activate the ignition switch due to the FUBAR steering column parts. So why not just unbolt the switch from the column and let it hang somewhere under the dash now you can easily activate the switch manually by hand without the key portion in the column. /forums/images/graemlins/peace.gif
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is one thing I am not sure about. Is the ignition switch the part the lock cylinder plugs into or is it the dual connector near the dash on top of the column? I don't know much about steering columns.
    I would rather rewire around the column then tear the whole damn thing apart.
    Harley
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Harley , the switch isn't too hard to change if you try . Lock cylinder turns a rod that runs down the column to the switch . Its a bolt on . Column usually just needs dropped a little /forums/images/graemlins/k5.gif
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The internals on the column are trashed. Changing the switch won't do anything. I pulled a bunch of little broken peices out of the column on Saturday.
    Harley
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That sucks . Last time I bought a column was 10 years ago for a Dodge and it was 25 bucks . Have you called around ? /forums/images/graemlins/k5.gif
