wiring from gas guage to sender question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5-newbie, Jun 21, 2004.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    My rig came factory with the 6.2 diesel in it and was converted to a 305 before I bought it. the wires coming from the sending unit are cut at the engine side of the firewall. there are two wires, looks like a pink and an orange but they could be faded. I need help in finding where they connect on the inside of the cab. I am assuming one gets power when you turn the key on and the other sends a resistance to the gas guage to move the needle in conjunction with the sending unit, but i dont know which does what. Does anyone know or have schematic to help me out.
    Thanks in advance and sorry so long.
  2. dyeager535
    26,982
    191
    Pink wire is the only wire that runs outside the cab (related to the fuel sending unit) in non-EFI applications for the gauge.
    Power and ground are done through the printed circuit board on the back of the instrument cluster. As long as your other gauges work, when you re-connect the cut pink wire, your gauge should work.
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    From the tank I think that the wire should connect to the fuse block wiring harness thing that is on the firewall on the engine side of the cab near where the steering column comes out.
  4. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    the sending unit has 3 wires coming from it, a black, pink and orange. the black is grounded at the tank and the other 2 follow the frame up to about where the shocks are and at that point they are cut. the wires end there, and I cant find where to connect them back. Thats why I was asking where they are in the passenger compartment. I thought then I couldjust run wire through the firewall and connect them to the cut wires and then maybe it would work. I'll keep searching the vehicle and try to find them.
    Thanks for the replies.
  5. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    Well, you were right...I found the little pink wire cut at the firewall where the wires feed into the fuse box and ran a new wire from it to the cut wire at the frame and my fuel gauge seems to work. at least it is not sitting at the 3 oclock position.
    There is still a cut wire in the harness coming from the sending unit it is tan, not orange as I thought originally. does anyone know where this wire goes??? /forums/images/graemlins/dunno.gif
    And again, thanks for the help, I will know tomorrow when I go to put gas in it if it works.
  6. dyeager535
    26,982
    191
    Almost sounds like a TBI sending unit. They are the only ones with the "extra" wire I can think of...oh wait, diesel eh? Do you guys have a water in fuel light or something monitored at the tank?
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yep, the diesels did come with the the water in fuel light.
  8. dyeager535
    26,982
    191
    Is that where it is monitored from then? Guess I never thought about it before.
    On a related note, do the diesel tanks have any sort of drain incorporated in them? I know the diesel car fuel tanks did.
  9. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    sounds like the wire I was looking for...you guys ROCK
