Wiring Gurus Help Please!
Discussion in 'The Garage' started by txfireman110, Dec 15, 2005.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Got the dual electric fans put in and I'm trying to fugure out how to wire them up.
    I have an On/Off/On switch and am trying to make it where On#1 is MAIN fan, and On#2 is BOTH fans withaverything tied to turn off with ignition.
    Right now I have Main fan On constant with ignition and 2nd fan is on switch and turns off with ignition.
    I'm confused:doah:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You are using relays right? How many and what are the contacts and coil numbers on it. If you give me that i will draw you a schematic
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Should be simple with 3 relays.
    3-way switch, "A" being 1-on, "B" (the middle) being off, "C" being both on.
    Switch pin A goes to the control for Relay 1, Relay 1 sends power to Fan 1. pin B does nothing (since it's off) and pin C has 2 wires and a 3rd relay connected to it, one goes to Relay 2, the other to relay 3, which switches on Relay 1. The purpose of the 3rd relay is to keep power from relay 2 when the switch in the "A" position.
    This way when you put the switch to A, it sends +12VDC to control for Relay 1, which then sends +12VDC to Fan 1. Switch goes to C, and it sends +12VDC to both relay control pins, thus power both fans. Switch goes to B, it sends +12VDC nowhere and both fans are off.
    Was that clear as mud?
    Here's a schematic :)
  4. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Relays??? What are Relays?!!
    Nope, I wasn't using any. Guess I'll get some! Any recomendations??
    And thanks for the schematic, that will definitely help!
  5. readymix
    May 30, 2004
    6,706
    26
    That schematic as drawn will not work. All 3 signal wires are connected together. I will edit it and show you what i mean
  6. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    A relay is a mechanical switching device. They usually are in black plastic boxes about 1" cubed and have 4 or 5 pins on the bottom of them
    A relay allows you to switch a large load with a small input wire. This allows you to run small wires and use small switches in the cab and switch on large loads (such as fans) without running a 30 amp load capable wire into the cab. How they work is when 1 "side" gets a small 12V electrical connection, an electromagnet pulls a large internal switch closed, thus switching on the large load through the relay. The switch only sees fractions of amps of current whle controling large amperage loads.
    I think they are $5-10 each. I have a few laying around my tool box for future electrical projects.
    Here's more info:
    http://electronics.howstuffworks.com/relay1.htm
  7. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    oh sh*t.. you're right. :doah:
    Fixed It....
  8. readymix
    May 30, 2004
    6,706
    26
    Danm, you beat me to it:haha::haha:
    I jsut installed PhotoShop CS and i am still trying to find all the differences form teh last version i had.
    What did you draw that in? I used to do all of my schematice in Circut Maker 2000, but it is no longer supported and i can't find the registration data for my copy:doah:
  9. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I'm at work (I work as a graphic designer) so I just slapped it together with our Layout software, Quark XPress.
    I have Adobe InDesign at home which would have worked just as easy for it. Photoshop would have worked too, but it would have been a hassle handling all those little lines & boxes in 48 different layers :eek1:
  10. readymix
    May 30, 2004
    6,706
    26
    Quark 0 Used it once. PITA IMHO
    Adobe - Used InDesign and Pagemaker. Both OK
    Photoshop - "Crtl-Shift-E" hahahaha
  11. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
