Wiring Gurus
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Feb 17, 2003.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    For about the last 2 weeks my alarm has been chirping and locking and unlocking the doors erratically while the truck is on. Alarm has been in the truck for 8 months. Replaced it, still acts funny. Checked grounds, replaced ignition wire, and it still does it. We are running out of ideas. The truck runs fine, starts fine, doesn't cut out, but I have to be getting a low voltage somewhere to activate the alarm. Any ideas?
    AW
  2. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I have seen where the battery is low on charge or is weak
    causing the alarm to go off for no reason.
    hope this helps,
    Bo
  3. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Brand new battery, running at full voltage. Checked alternator too and its fine.
    AW
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    How is the positive side wired? I agree with the low voltage guess.
  5. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Positive side of what?
    AW
  6. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    When the battery was replaced the terminals may not have been tightened all the way, check that and check the body ground. The body ground can be loosened when the battery is moved. The battery could also be loose in its mounts. This can cause the terminals to make and break contact as you drive. Check all the power connections to the alarm, if they use crimp connectors remove them and solder all connections.
