Wiring Harness for K5 72 Blazer
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by joryyroj, Mar 9, 2005.
  1. joryyroj
    joryyroj Registered Member
    Mar 13, 2003
    32
    Wylie Texas
    The OEM wiring harnesses are so expensive, has anyone ever used one of the aftermarket wiring harnesses like Painless? Are they as easy to use as they seem? Anyone know of any alternatives?
    http://www.painlesswiring.com/catlarge/10205.jpg
  2. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    You get what you pay for. The only thing I would suggest on Painless is to solder instead of crimping. Crimping will be fine for a year or two but after the wires start to corrode you will not make good contact, then you will have bigger problems. I used M&H Engineering for my wiring. They make OEM harnesses. I had like $600 for a total rewire. I bought it thru Tuckers. Tuckers sells it cheaper than thru M&H.
    http://www.wiringharness.com/
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Usually the cheaper the harness,the MORE complicated and involved it will be to install.
    I used M+H stock replacement harness and it was a simple plug-n-play deal.
    http://wiringharness.com/
    The painless harnesses have to be "adapted" to OUR year trucks.
    It also depends on your skill level and how comfortable you are with automotive wiring.If you compitant with wiring, go with the cheaper harness/wiring system.
    Finances are also something to consider.
    Personnaly I wouldn't skimp on your vehicles wiring.The more expensive harneses use quality wire,are properly wrapped,have the mounting clips wrapped into the harnesses and line up to all the factory mounting holes.
    They also have the proper terminal ends already crimped and soldered on.
    Just something to consider.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    are you guys using any grease for the connections between the fusebox and the front firewall wireharness. I've seen some harnesses corrode in that area.
    ARQ.
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I use dielectric grease on all the electrical connections I mess with. It gives a better electrical connection and prevents corrosion. Cheap insurance.
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    I don't know what kind of dielectric grease the factory uses but that black/brown stuff gets over everything.
    I used a quality marine dielectric grease.
