Wiring Harness Replacement
Discussion in 'The Garage' started by Tx70Jimmy, Jan 20, 2005.
  1. Tx70Jimmy
    Tx70Jimmy Registered Member
    Jan 17, 2005
    13
    East Texas
    I just ordered a Painless wiring harness for my '70 Jimmy to replace the rats nest the previous owner created. Any tricks or experience notes on replacing the entire wiring system would be appreciated.
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    well, I havent dealt with the body harness, but I can tell you from past projects using the TBI harness, it was AWESOME!! Everything is the perfect length, color coded so a tech manual will still work, all the wires are labeled, and the connecters plugged right in. I am sure the other harnesses will be the same way. You will be amazed at how easy it is to do, and how much information is in the instructions.
    over all-----two thumbs up.
    :thumb: :thumb:
    Hope this helps.......Rob
