Wiring Harness
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fmf_corpsman, Apr 4, 2007.
  1. fmf_corpsman
    fmf_corpsman Registered Member
    Dec 12, 2006
    20
    Afghanistan
    Any body have any suggestions for a wiring harness for the back half of a 90 GMC Jimmy. Thanks in advance.
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Are you talking tail lights, trailer hookup and fuel tank stuff or what?
  3. fmf_corpsman
    Dec 12, 2006
    20
    Afghanistan
    Pretty much from the firewall back. I cant figure out what the problem is, it has no left taillight. It has brakelights both side. I have no cigarette lighter power. The hazards flash fast and weak. I figured it might be easier to run all new wire than to track that down. I checked the filament in the bulb, but they were all good.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You might start by changing the flasher. When a flasher goes bad the lights usually flash rapidly and sometimes dim. Also bulbs are cheap enough that i would replace them all. Sometimes the break in the filament is in an area you can't easily see. Also the bottom of the bulb where the connections are sometimes gives a problem. I'm not talking about the connector that the bulbs goes into but the bulb itself.
  5. fmf_corpsman
    Dec 12, 2006
    20
    Afghanistan
    OK< im willing to try anything. I have to drive on Base, and they are real strict about that crap. Thanks. Well see what happens
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    yup, start with the cheap replacable basics.. bulbs, flashers, connections, grounds, etc...
    You can test sections too... disconnect and check the harness plugs in the back by the bumper.. while apart send 12v thru the turn, etc lead directly to the taillight, that eliminates from that point back as a prob, etc...
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Grounds are the single most leading cause of the troubles you specify. Check your grounds back there.
