wiring help? (tail lights)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Feb 22, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    got a tail light out
    brake light works so replacing the bulb isnt the problem
    the other taillight works so even if there were fuses for it id say they were fine....
    what im wondering is it anyone has a wiring diagram or a guide or anyone wanna type out how i should approach this.
    got a ticket tonite so im pretty motovated to get it fixed.
  2. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    I believe it is a 2 fillament bulb.Might be just 1 fillament out.
  3. tecton
    Dec 1, 2002
    1,553
    WV
    switched bulbs
    the left tail light circut isnt workin
  4. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    I had a similar problem with a 85 truck I had. There was a short in the turn signal switch itself. Try gently moving it up and down and see if it will come on. On mine you had to push it up slightly for the left tail light to work. You could also have a bad wire or ground somewhere which will take a test light or voltmeter and some wire tracing.
  5. tecton
    Dec 1, 2002
    1,553
    WV
    wire tracing is a pain... to do in the rain(?)
    *sigh*
  6. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I had the same problem in my lights. Turned out that the part of the harness that splits off and goes to the left and right lights was disconnected for the left parking light only. Everything else worked. All I did was connect a wire from the right to the left parking light wire and now they work like new. I couldn't get to the harness for now, but come the warmer months I will fix it the correct way. If it was the switch all parking lights wouldn't work. According to Chilton's, the wires colors for the parking lights are brown, green and yellow go to the directionals, and light green goes to the back up light. Hope this helps.
  7. tecton
    Dec 1, 2002
    1,553
    WV
    i got out in the freezing rain in a lit parking lot and got back there and looked on my way home from work
    found what your talking about and ill fix it in the morning
    thnx
