Wiring help
Discussion in 'The Garage' started by airbornesoldier327, Mar 8, 2006.
  1. airbornesoldier327
    airbornesoldier327 1/2 ton status
    Feb 11, 2005
    134
    north carolina
    I have a quikie for you, i have 4 KC's on top and would like to know if i need to run that relay that it comes with, or can i run it strait to the power source, with a in-line fuse of course?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    it would be better to run the realy so you are not running all the amps through the switch directly
  3. airbornesoldier327
    Feb 11, 2005
    134
    north carolina
    Thanks for the help, so where woudl i pick up a replacment relay? Would autozone or discount auto have them...
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Any autoparts house should have them, if nothing else, you can get them at Radio Shack :thumb:
  5. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Here's a site where you can order a bunch of lighting doodads, anything from screws and clips to a Hella HID light set or pencil beam driving lights:
    http://www.rallylights.com/
    They've got relays and harnesses up the wazoo. I ordered my Hella headlight conversion kit from them, and had very good service, fast to ship.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I get heavy duty 50 amp relays for stuff like that from JC Whitney..............course I am an old fan of there's!
  7. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    Definatly use a relay. I've been getting them at O'reilly's for about $4. It's actually pretty simple to wire one up. I never used to use them, but once you've hooked one up you'll see it's pretty simple and you don't need to worry about having to find a 20 amp switch for inside your cab or anything like that.
