Wiring My Winch
Discussion in 'The Garage' started by IDGMC, Mar 10, 2005.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    Ok, So what gauge wire should I be using to run from my battery to the classic 8274? I've got 4 gauge now, but am worried that isn't heavy enough? Also my wire rope is in need of replacing, who would you guys get yours through?
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I personally used *i think* 2 ga welding cable. I made my own cables and soldered lugs onto the ends. This has worked very well for me, but I have heard there is a better way than this for wiring something that draws such a high number of amps. Wish I could remember the type of wire, it was a "camp fire" discussion a few wheelin trips ago. And on the wire rope, maybe check out ebay. I have seen it fairly cheap on there.
    __________________
    '77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
    http://www.krazyk5.com
    http://community.webshots.com/user/trcksr4me
    http://community.webshots.com/user/trcksr4me2
  3. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i have o gauge, wich is a bit of overkill.
    and i use amsteel from rockstomper. very cheap. and i can use it cause i have an 8274 (no internal brake)
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I used 1 gauge and got the connectors at NAPA.
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Ummm, what does the Rockstomper link have to do with wiring a winch?? :dunno:
    Has the sand started taking it's toll on you :D
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
