Wiring Offroad Lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Jun 18, 2001.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    In the diagram that came with the kit it shows a wire going from the switch to the fuse box. How do I connect to the fuse box? Does it just need a 12V source or is there something on the fuse box I connect it to? The switch is connected to a relay which is connected to the battery and lights. Thanks.
    Brian
    <A target="_blank" HREF=http://84k5.coloradok5.com>http://84k5.coloradok5.com</A>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Often there is a place for a extra acc. that you don't have in the fuse box. If you take a male spade terminal it will plug into the spot where the fuse would go. One side will be hot the other will go noware. Use a test light to find out which is which.
    '71 Blazer CST with alot of rust
  3. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If your accesory terminal in the fuse block is already taken, most auto parts stores have "fuse taps" that you can hook around a fuse and hook a .25" female spade to, or since this is just the lead to kick the relay, you can splice it into the wiring for your parking lights, and have your off road lights work off of your headlight switch.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
