wiring offroad lights
Discussion in 'The Garage' started by RootBreaker, Feb 1, 2007.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so some of my lights are wired up but I want to change some things...
    I have power to my relays and relays to switch and lights...
    I am using a standard automotive GM relay.. pn 25553347
    relay is rated for max of 30A
    kc light is rated at 12A each
    I am looking at metri-pack 280 connectors.... not cheap but i found a cheap place. However the metri-pack 280 is rated for 30A and the metri-pack 150 is rated for 14A ... since my lights are 12A each.. it wont hurt getting the metri 150's right?
    p.s im gonna share the link soon... still doing my research.. and get my order in first... :wink1:
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    150's will work just fine.
    These are conservative ratings Delphi uses, unlike the aftermarket. They supply to OEM's, who size things appropriatly. 14a rating means 14amps continous without problem. So go for it!
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Hey, nice H-Car relay/Fuse center BTW.
    Same setup I'm using!
    I bought all the pull-to-seat 480 terminals for the relays so I don't have to splice the wires.
    I also bought the 800 series terminals for the maxi-fuse block.
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    yeah 1989 olds 88... I got that for a steal so wasnt worried about everything else..
    $10 score!!!!! with relays and fuses.. :wink1:
    it also used factory mounting bolts on my truck.. that is why it is tilted....
    I am going to clean this up....
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    838
    Pinckney, MI
    Nice I need to go to the local yard and pull one. I know there is like a gazillion of them in the yard.
