Wiring question
Discussion in 'Audio' started by Drey, Dec 28, 2006.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Im hookin up the XM radio i got for my blazer, Can I just splice into the 12 volt source and ground for my CD player? Then I can have it set up to only one when the Key is on ya know.
    It came with another cigerette type connecter to plug the 12 volt to 5 volt adapter into, so im not going to have an issue there.
    I could use one of my 3 other cig type deals but im trying to keep it lookin clean. Thanks guys
  2. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    I recommend just running a new hot wire over from your fuse panel. As for the ground, its a chassis ground setup, no need to splice into a current ground, just run a new one to the closest piece of body/chassis sheetmetal or bracketry. Especially if you used the factory wiring harness for your CD player, they can be quite 'noisy'.
