Wiring question
Discussion in 'The Garage' started by bunde89blazer, Feb 12, 2003.
  1. bunde89blazer
    bunde89blazer Newbie
    Feb 12, 2003
    I was wondering if anyone had a wiring diagram i could download anywhere or knows the color and location of some wires i am looking for to install a remote starting system on my full size 89 blazer, i know they are located on the ignition switch but i am not sure which ones are the ignition output:hot when key is turned to start or run, could be 2 wires? accessory wire:hot when key is on accessory or run of course, if anyone knows i would appreciate the feedback thanks.
  2. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    you could go to a mechnics shop and ask the to print or look up a dirgram for you, good luck. /forums/images/graemlins/k5.gif
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Here is a page that has '89 Suburban wiring...should be almost exact for what you are looking for.
    '89 Suburban Wiring
    This should be the specific page you need:
    Ignition/fuse box
  4. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Also might try the public library. Look for the Mitchell books. Can't check em out but you can make copys. Thats where I got mine.
    Sam
