Wiring questions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70jimmy, Feb 18, 2005.
  1. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Wiring questions (pics added)
    I am re-assembling my dash after about 1.5 years so some things aren't real fresh in my mind.
    There is a plastic box with 2 wires coming out one side and it looks like there should have been two wires going in the other side. The box is 1 inch tall by 1 inch deep by 1 and 3/4 wide. Inside of the box the wires are soldered to a piece of copper. I only have one wire going in the one side and it goes to the fuse panel and is connected to a spade in the spot labeled ignition unfused. this is on the lower right of the fuse panel. I am wondering if this was the power for the stereo? Thanks.
    Did I mention I hate wiring. I am trying to get everything working again and then I will probably just replace the harness.
  2. 70jimmy
    Mar 3, 2000
    5,962
    252
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That to me looks like the power and ground that came off an aftermarket stereo. You are correct in thinking there should be 2 wires coming out of both sides of the box.....1 power and 1 ground on each side
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Poss. a relay of some sorts?
    All I know is that our Blazers never had anything like that installed from the factory.
    Sorry I can't provide more info.
    Hopefully someone else can I.D. this mystery box!
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Duno:confused:
    I would just chuck it and move on. I riped alot of unused wires and inline fuses from under my dash when I did my gage cluster. It is amazing how much collects under there over the years and thru the different owners.
  6. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    Yep that's an old stereo connection. I think it was used to dampen voltage spikes(not positive). Looks like your havin some fun now:D
  7. 70jimmy
    Mar 3, 2000
    5,962
    252
    Thanks for the responses!!
    Now to get back to wiring :crazy: :mad: :( :eek: :dunno: :screwy: :yikes: :hack: :angry1: :grind: :weld: :whistle: :1zhelp: :doah:
    Whew good thing most of the stuff has only 12 volts!!! Hmm why is my hair getting curly and what's burning?????
