Wiring Routing Help....
Discussion in 'The Garage' started by desertfox, Feb 8, 2005.
  1. desertfox
    desertfox Newbie
    Feb 8, 2005
    3
    Phoenix, AZ
    I have an 84 k5 with a roof rack with lights mounted on the rear that have never even been connected. After two years of looking at useless lights, i tested them and found out they work (I bought the rack used with the lights attached). So next was figuring out the best way to get power to them. I was going to run wire though the same route as the dome light in the back left, but I cannot get the wire through there. Would this be the best place to send the wire, if so, whats the best way to get the wire through there (it likes to bunch up by the corner.)
    PS If any of you are from AZ and remember haulgas (brian), he is my dad. Just to let you know.
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Build a box put a few relays in it, route it to a switch pannel for future use. Do it right the first time! so you dont have to rewire again.
  3. desertfox
    desertfox Newbie
    Feb 8, 2005
    3
    Phoenix, AZ
    That was my intention, just having problems routing the wire from the front of the truck to the back.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    SE IF YOU CAN SNAKE THE WIRE WITH A PIECE OF COAT HANGER OR SOMTHING, I WOULD DRILL THE HOLE TO GO TO THE ROOF RIGHT THROUGH THE DOME LIGHT, THAT WOULD MAKE IT SUPER CLEAN, JUST MAKE SHURE YOU SEAL IT GOOD,
    oh crap sorry about the caps, i was dooing a report at work:o
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I drilled a hole through the roof. Ran the Pos. wire to the lights and they are grounded top the rack (I hooked the Neg wire to the mounting bolt).
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if it is at the back just tuck the wire under the plastic trim where the walls meet the roof, bring it out the back and i would drill a hole under the mount for the lightbar/rack, so you can seal it.
    or use a gromit, you drill a larger hole the gromit goes in the hole covering the eges and the wire will be tight to it some sealint and your laughin
  7. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    Just Get 2 Wires, And Cut The Existing Dome Light Wire, Hook On The 2 New Ones And Pull Them Trough The Dome Light Hole, Replace The Wire You Cut With One Of The Wires And You Have Your New One Snaked Through
  8. desertfox
    desertfox Newbie
    Feb 8, 2005
    3
    Phoenix, AZ
    I actually thought about that, and I think thats what I am going to do, I was just afraid of the wires coming loose and losing all progess!!
    Thanks Guys!
