wiring the horn button....
Discussion in 'The Garage' started by jekbrown, Jan 25, 2003.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I have a grant steering wheel (el cheapo type) and cant figure out how to wire the horn right. The way it is now... the horn is ALWAYS on, unless I pull the fuse or disconnect the wiring. the instructions that came with the things work on about 500000 different steering wheels so they arent all that specific. any ideas? /forums/images/graemlins/frown.gif
    j
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    couldn't tell ya, my horn hasn't worked in years /forums/images/graemlins/rotfl.gif
  3. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    The wire you use to replace the plunger connects to the center terminal on the horn button. The other terminal off to the side touchs the retaining ring. Thats how you get your ground. If your horn in always on your the wire is grounding out on something. If that doesn't make sense I can get some pictures of mine.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There should be an insulator that installs between the horn button and the rest of the assembly. When the button touches ground, it should activate the horn.
    Also, if you unplug just the horns to keep it quiet, but leave the circuit active, the coil in the horn relay will burn itself out. It wasn't designed for a 100% duty cycle. /forums/images/graemlins/frown.gif
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Can you get some pics for me? I replace my steering wheel on my 75 burb with a steering wheel from a 89-91 truck and the horn mechanism is different so i need to figure something out /forums/images/graemlins/grin.gif
  6. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    Ya, I'll try to get some pictures before work on Monday. I have a grant wheel on mine. The horn is re-wired for it. Don't know if it will help but will get some for ya anyways.
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    that would rock, I'd appreciate it. Pics my not solve the problem entirely, but they would surely make the trouble shooting process shorter. /forums/images/graemlins/smile.gif
    thanks in advance!
    j
