Wiring up the KC's
Discussion in 'The Garage' started by 78Suburban, Mar 12, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I think I'm gonna run all 4 off of one switch. What size relay should I use? their website's wiring kit says 40 amp, I guess that's a good size
    http://www.kchilites.com/store/Deluxe-Wiring-Harness-6315brwith-40amp-Relay-P113C83.aspx
    I'm also going to put an inline fuse about 2 feet from the battery. I guess 30 amp would be a good size? I'm going to run 12 guage wire.
    Anybody wanna share any ideas with me? Are there any reasons I should cosider using 2 swithces controlling 2 wires each, instead of what I'm planning?
    thanks,
    James :bow:
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    If you are going to run all 4 at the same time, you might want to consider running 10 gauge. 12 awg-20amps, 10 awg-30amps, 8 awg-40amps.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You need that relay for TWO Daylighters. :eek1: If they're the sealed beam type, they draw 150 watts each. 150x2=300 watts/12 volts=25 amps. You can power two relays from one switch, then feed two lights from each relay.
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I think they are only the 100 watt kind. So do I still need two seperate 40 amp relays, or can I just use one 40 amp relay for all of the lights? I guess using 2 seperate relays would allow me to use 12 ga wire instead of 10 though?
    thanks,
    James
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I would still go with dual relays. That gives you the option of going with even brighter bulbs later. 130 watt H3 halogens cost about the same as the 100 watt ones. :)
