Wish me luck
Discussion in 'The Garage' started by mountainexplorer, Feb 14, 2003.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I'm headed back out to Pull and Save to try and snag a 14 bolt out of a 1-ton 2wd truck. It was a factory 6-cyl/4spd, so I'm hoping two things:
    1. that it has 4.56 gears
    2. that it's still there when I get there
    Also, does anyone know if front 1-ton 2wd calipers are the same as 1-ton 4x4 (D60) calipers?
    I also spotted a 14 bolt in a fullsize van. What was the most common gear ratios in the vans? I'd assume it's probably 3.73, but if it were 4.10, I might try and snag it, too.
    It's $86 for a whole axle assembly.
    I hope I'll be coming home tonight with 4.56 gears. /forums/images/graemlins/cool.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Well good luck. /forums/images/graemlins/thumb.gif
  3. mountainexplorer
    Nov 14, 2001
    4,903
    Thanks. /forums/images/graemlins/smile.gif
    I got it pulled and brought it home. Didnt even take the time to check the gear ratio. I hope it's 4.56's...if I just went through all that work to get another 3.73 14 bolt... /forums/images/graemlins/angryfire.gif
