? with studdering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Dec 8, 2001.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok here goes when I am at a stop light my blazer wants to creep foward like it is studdering and wanting to inch forward on each studder. (and yes my foot is on the brake) Thank you
  2. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    it could be that its idling really high or the throttle cable gets stuck and its giving it gas with yer foot off the gas pedal. just go to the linkage and grease it. as for the idling try and adjusting it. later.
    jacob
    what is that low rider doing under my k5?
    wow nice lil jap car. whats it good for?
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    ya thought of that one and the tach says it is only idling at about 800-850
  4. k5ntexas
    Oct 29, 2001
    2,517
    ok. well. hmmm got me in question too. maybe the tach is off? i don't know. sorry. later.
    jacob
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    We ne-need a bit more info. H-h-how does it idle ou-out of gear (high-surges-inconstant)? Does it consistantly act like this? Is the drive train current with the '73 - nothing upgraded- yet? Cold-weather?
    Possible causes that come to mind:
    High idle setting.
    Choke isn't pulling off correctly.
    Worn throttle shaft bore.
    Vacume leak
    More details may help.
    <font color=blue>Twiz</font color=blue>
    Can't get it up?
    So, drop it in
    gear.
  6. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    ok here goes out of gear it idles about 1000 after it is warmed up,with my foot on the brake waiting for the light to change it will idle about 850 in gear and it is like I am a a kid and letting go and pushing back on the brake to make the truck shake. But it just moves a tad bit and it only happins when it is a long light or have to sit for a while in gear (if it is the carb then I will have to wait till jan and then I will get tpi or the holley pro jection) hope this helps
  7. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    the motor is all stock just new wires and the such,stock drivetrain (for now till jusne when my bonus comes he he) I have replaced the acc.pump and that helped but then went to the mountains 5000 ft and started running with a studder at take off and this problem came on
  8. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Idle speed is way-to-high. It's up against the converter in-gear and tring to move the truck- basicly your "power-brakeing."
    Check the list above. Choke, idle setting, vacume leaks, and the throttle bore for wear.
    I think the normal out-of-gear idle speed should be around 650 - 700 RPM after the choke lets go.
    Can't get it up?
    So, drop it in
    gear.
  9. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    thanks I will check it out this weekend
  10. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
