With winch should I go with?
Discussion in 'The Garage' started by blazindorito, Mar 8, 2004.
  1. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    I need to purchase a winch. What do you guys recommend I get for a 83 k5 blazer with 3/4 ton rear end dana 60 up front.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Do a search, this is covered indepth at least once a month. Here it is in a nutshell:
    Warn electric rated for at least 1.5x the weight of your K5...
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    go with at least the warn hs9,500i or better i have the xd9,000i and it has been great for me but the hs9,500i is way faster /forums/images/graemlins/thumb.gif
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    If you can afford it, go for the biggest warn you can fit
    If you need speed go for the HS ones
    If you need multimount get an integrated solenoid one
    If you're a poor broke bastard buy the MM E12000 or a used Warn
    I haven't looked into Ramsey much
  5. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    I have been Running a mile marker 9000 for about 1 and a half years. It has held up great under some serious abuse and was very cost effective. /forums/images/graemlins/thumb.gif
  6. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yeah I have the 12000 and I hope it works as great as I hop... wait that was redundant, or..... self defeating.... or some wierd english law breaking thing.....
  7. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Warn 9.5ti or 16.5ti if you have the cash. The 9.5ti replaced the hs9.5. I saw this winch in action a lot this weekend and it rocked. It's very fast and should move your Blazer around without a problem. Give Tim with 4x4Iron.com a call. He has 3 or 4 of the 9.5ti's in stock and can make you a great deal on one. His number is 512-626-2161. I believe his prices are between $100-$200 less than 4 wheel parts.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have the MM E-12000, I hope it works out good for me. /forums/images/graemlins/thumb.gif Price sure did, and it's better than no winch at all.
  9. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    I had a 3.6 hp Ramsey 8000. Worked ok with worn 36 TSL radials. Almost left me stranded w/ 38.5 SX's. New Warn 12K does the trick every time so far. By the way for me the 12k was beter than the 15K because of the extra 35 feet of cable. The Warn makes the Ramsey seem like a kids toy.
