wives and trucks !!!!
Discussion in 'Rocky Mountain Region' started by teamhickman, Feb 28, 2005.
  1. teamhickman
    teamhickman 1/2 ton status
    Aug 28, 2004
    Buckeye, AZ.
    What a woman I married!:D
    So I get home from work today and the wife tells me there’s an issue with the truck title. So I immediately begin to bitch and she tells me to take a look at it. I open the file and see that the title has been changed over and she took it through emissions!
    Man what a surprise!:thumb:
    I couldn’t believe it…….she drove it, got the title taken care of and ran it through emissions!!!! She said it was hilarious when she got to the test station…..4 tech’s came over and in disbelief asked if she needed a hand getting in and out. God I would have loved to see that.
    Anyways…I love her and I love the fact that she was willing to do this today!!!
    So on to the emissions results…….
    HC in PPM (loaded)
    loaded reading = 193 Passed
    loaded standard = 400
    HC in PPM (Idle)
    Idle reading = 1026 failed
    Idle standard = 400
    CO in % (loaded)
    Loaded reading = 0.37 Passed
    Loaded standard = 3.75
    CO in % (idle)
    Idle reading = 0.31 Passed
    Loaded standard = 5.00
    So it looks pretty good……I assume at this point a tune up, timing verification, carb adjustment or rebuild will get the idle HC within limits.
    Any thoughts?
  2. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    mesa AZ
    u are one lucky man. im hopin that one day i will find some one like that:grin:
  3. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    Phoenix AZ
    With HC that high at idle, it should have a fairly substantial lean-miss at idle and smooth out once you are off idle. You can go ahead and do your tune-up, but before you use your free re-test, I would back the idle mixture screws OUT until that lean-miss goes away. With the CO being low and the HC being way high, it indicates that the idle mixture is waaay lean (could be a vacuum leak, but those will often affect the loaded readings as well). With the loaded numbers where they are, it looks like the motor should be in pretty good shape (combustion-wise).
    Congrats on a good score there (truck and wife:D )
