WMS Doubler
Discussion in 'The Garage' started by sageman, Jun 19, 2003.
  1. sageman
    sageman Registered Member
    Sep 27, 2002
    40
    Calgary, Alberta, Canada.
    Seen one in the galleries and it has the 203 inverted and the back is now the front.
    If you understand this... is an overdrive set-up and not an underdrive?
    p.s. its' in mudzers' gallery!
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Post a link to Neils pics as some of us are too lazy. /forums/images/graemlins/deal.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/rotfl.gif
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    My WMS Doubler is not turned around as you thought, its in the same orientation as others on this site - however, you are correct in saying the NP203 Range Box is inverted and the NP205 is clocked up to flat (inputs and outputs are level).
    This gave me a ton of clearance, but I had to sacrifice clearance with high driveline angles and a hole cut in the floor.
    To get an idea of how much clearance I gained, measure from your crank centerline down 6" and thats where the bottom foot of my adaptor sits. I have the T Cases set just below the bottom of the frame with bottom of crossmember at 1.5" below bottom of frame.
  4. sageman
    Sep 27, 2002
    40
    Geesh... I'll say!!!
    This side your looking at is (to me) the side of the range box that would attach to the chain case of the 203 when it was a whole unit. It is now flipped around and has a input for a th350/th400 tranny...so is it and over or under drive?
  5. sageman
    Sep 27, 2002
    40
    Sorry.. my bad!!
    I fully understand now, thanks!! /forums/images/graemlins/grin.gif
    It's just deceiving without the tranny adapter.
  6. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    who makes a WMS doubler like that? or where can I get info on it. Thanks!
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    WMS makes them. /forums/images/graemlins/cool.gif
    Wagoner Machine shop. I think I spelled it wrong.
    Ken H.
  8. Mudzer
    3,639
    Missouri
