WMS dueces 203 output bearing retainer ?'s
Discussion in 'The Garage' started by MNorby, Mar 7, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    How does the bearing retainer go in the back of the 203 between the doubler adaptor? There is an ear on it the seems to hold things up.
  2. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    The stock bearing retainer ear is for anti-rotation. Generally those who make dual case kits that retain the stock basket will have a female index hole for this to fit into, some will tell you to grind it off.
    Others, ourselves and ORD included have done away with the stock bearing basket and have integrated it into the adaptor kit. Two ways to skin a cat - or install a range box - whichever is your preference.
  3. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    The doubler adaptor has no provisions for that tab so prob just grind it off? Also basically the series of parts is the new output shaft for 203 then the big gear, that thrust washer then the bear/retainer then snap ring, correct?
  4. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    The order of parts you have listed is correct, don't forget the anti rotation pin at the thrust washer.
    The reason the anti-rotation tab is there, if for some reason the force to rotation the bearing exceeded that of the bearing 'basket' the basket would start to spin, and destrtoy itself in short time, the short answer is that the tab really should have been built into the dual case kit, but in your situation, looks like grinding it off is in order, that or have a machine shop put a notch in there if material will allow.
  5. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    Cool, I'll just grind it, ain't skeered. Thank kindly :)
  6. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I just finished mine a few months ago and I verfied with WMS that the tag needs to be ground off. Be sure not to get shavings in the bearing.
  7. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    Got it done this morning and put together. Thanks! Now to put my 205 on and build some shifters :)
  8. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Actually, My WMS Dual Case had a small bead of weld about 1" long that would index that slot after removing the tab. Did yours have this?
