Wobble when I stop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by unick, Mar 27, 2005.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    My truck wobbles like hell when I stop sometimes. Anyone know what could be causing this? It doesnt happen all the time just once in a while and its anoying as hell. I think it might be the stabalizer but Havent looked into it at all. Any Ideas>
    LMK
    NIck
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Rotors...They are most likely warped. Mine were warped and they would only "wobble" depending on how much brake pressue was applied..
  3. unick
    Aug 16, 2003
    4,286
    I doubt its that cause it doesnt happen all the time. Only once in a while. Its a really bad wobble too it shakes the whole damn truck.
    Nick
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Sounds like a case of death wobble if it feels like it will wobble you off the road when you stop.....
  5. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    it does sound like death wobble- jack up the front end and grab each tire and try to see if it has up and down movement. grab it , see if there is any play in the ball joints or kingpins.
  6. unick
    Aug 16, 2003
    4,286
    ****ty that probably what it is. Im going on a drive from San Diego to South texas tomorrow too. God damn truck must not want to leave cali. Lol im going anyway :)
  7. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I let my tires go too long without a rebalance on my DD a year or 2 ago and it did that. I never got the "wheel hop" going down the road... nothing it felt smooth then. But, when I would stop it felt like I was driving over something .. real lumpy. I had em' rebalanced and it was fine after that. I also noticed that different roads/textures seemed to make more noticable than others.
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    yep rebalancing tires can cure alot
  9. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    my money is on the wheels being unbalanced. or a combo of that and the stabilizer is bad. thats what was wrong with mine. it was intermittent like yours. mainly when i went over RR tracks or a pothole while on the brakes.
  10. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Kind of a long shot here, but easy to check. I had that problem. Turned out to be a defective tire (the inside plies seperated). I didn't find out until I had a blow out on the freeway ... didn't wobble at stops after I put the spare on!
    I got the same wobble a year latter, pulled over, checked the front tires and found one had the tread all deformed (from the insides seperating). Put the spare on right then and went and bought all new tires. These were load range C Dick Cepeks .... no wonder they went out of business!
    Eric M.
  11. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    That's funny, I had a set of Dick Cepek MC-II about 4 or 5 yrs ago and 2 of those had broken belts and caused me all sorts of problems. I bought them at Vic Hubbard in Fremont but they said they were out of warranty since they had more more than a few months drive time on them. Oddly enough, that Vic Hubbard location is no longer in business either.
