Wobble
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Toad, Apr 5, 2001.
  1. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    I get a wierd wobble when going slow. I notice it on the pavement when going about 5 mph. Kind of like a rocking motion from side to side. I've had the tires balanced but it still does it. Could the tires be out of round or could the axle shaft be slightly bent? Any ideas?
  2. doonjumper
    doonjumper 1/2 ton status
    Mar 9, 2001
    948
    Visalia, California
    Check the tires for any obvious bulging. You could have a tire separation. If you don't see anything obvious then try different tire positions. Rotate your tires front to back or left to right. If the wobble changes then it's your tires. Make sure you mark all your tires so you know which position they are in before you start.
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    This might sound silly, but...
    Are you on mud tires (Swampers, BFG MT's, etc)?? Any tire with big lugs will have a little bit of slow-speed vibration/shudder as it rolls from one lug to the next.
    Couple more suspects: Bent axleshaft (10/12-bolt rear), bent hub assembly (any front/14-bolt rear), bent wheel.
    [​IMG] Semper Maintenance!
  4. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    I'd switch the wheels around and see if it changes. Bent rim a possibility....could still balance out ok. Anyone of the wheels have a lot more weight added to it to get it to balance?
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  5. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    I had the same problem. When I checked the ball joints they were loose. Replacing them cured the problem. Best of luck.
    John
    So Much to do, So LITTLE cash.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I also had this problem and had a loose balljoint....
    <font color=green><A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A></font color=green>[​IMG]
  7. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    Thanks for the replies. I didn't think about the balljoints. I'll jack it up and check it out next week and check the tires too. Thanks.
