wondering
Discussion in 'The Garage' started by iwaxmyjimmy, Nov 3, 2006.
  1. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    i just bought a 87 GMC jimmy w/ 72K miles all original besides a cd player and some pacer bulletholes w/ 33 BFG muds. it tends to wonder all over the place im thinking its the steering stabilizer. does this sound familiar to neone?
  2. Txchevy18
    Txchevy18 1/2 ton status
    Aug 29, 2006
    225
    Tx
    Sounds more like a a tracking probelm. I would look at the ball joints being bad and check the steering linkage for loose and worn steering parts. A steering stabilizer just helps to dampen road inconsitencys as you drive over them. Good luck with the rig and welcome to ck5!
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Sounds a little more than just the steering stabilizer check all the U-joints on the front end. I am sure you will find they are a little worn out. Welcome to CK5!!!
  4. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    well its like every little movement of the wheel and it goes that direction like alot of play in the steering
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
  6. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    ok thanx thats alot of good info. ill check it out and let yall know something
  7. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    found it to be a driver side wheel bearing being a lil warn w/ about an 1/8th inch. movement. should be replaced maybe next weekend along w/ front pads and rotors(he gave me the rotors with it). i had to pay rent this week.
    cant wait to start building it up ive been looking a sliders and bumpers for about an hr now.
  8. Tannerman
    Tannerman Registered Member
    Aug 22, 2005
    13
    Canada
    When I got my truck I had a similar problem and after replacing one or two parts I started to suspect the pitman arm. Ordered a new one and after I swapped it in it was a huge difference.
