won't idle when cold
Discussion in 'The Garage' started by sled_dog, Apr 8, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    won\'t idle when cold
    My K5 just doesn't idle when its freezing cold. Past 2 days has been 30s and snow so anytime I drop it out of gear and let the rs come down I have to give it gas or it will stall out. Any ideas what this can be? If I am sitting still and it starts to stall I pop it a couple times and it will idle fine.
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Re: won\'t idle when cold
    Upgrade to fuel injection /forums/images/graemlins/thumb.gif
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I wish I could afford it. Someday
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    might turn idle up a little bit or maybe advance timing 1 or 2 degrees.
  5. jhrody
    jhrody 1/2 ton status
    Feb 16, 2003
    129
    Elmhurst, IL
    mine was doing the same thing until i adjusted the idel mixture.....mine was running tooooooooo lean. I backed outt he screws until I achieved the highest vacuum reading.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    timing is advanced 2 degrees as is. 6 factory spec is 4. Sometimes it idles a little high so I think idle is set pretty rich.
  7. jhrody
    Feb 16, 2003
    129
    Elmhurst, IL
    yes, you can also be running too rich.....when its cold, the choke is causing more fuel to be dumped into a potentially already too rich mixture--- when it opens after warmup, it's going to run better.
    I'd double check that mixture with a vacuum guage. /forums/images/graemlins/laugh.gif
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    see even after the engine warms up this happens. Today when I was driving home from school it almost stalled like 3 or 4 times and did 2 times. I don't mean when the engine is cold I mean when its cold outside! With the radio on I know when its about to stall I can feel and see it in the [censored] lever, steering gets tight and so do the brakes, nothing scarier than hitting th ebrakes and finding little there and same for steering.
  9. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    mine does the same thing..you just gatta get the hang of the gas and how to treat it when its cold..thats just part of having a carb...carbed engines wont go anywear when they are first started up in the mourning..in fact mine stalled out a couple times backing out of the driveway this mourning..but once it gets warmed up..its smooth sailing..
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    when its cold outside that will make the engine cold. if its warm out like 70ish or better then engine stays warmer, when its nice and warm like that, i dont even have to let my truck warm up i can just start and take of..but when its cold like it is outside i usually have to sit a couple minuts and let it warm up...i know when its ready to go when i can rev the engine quick and it wont sputter.. /forums/images/graemlins/thumb.gif
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yes I know that I have driven a vehicle before. I understand the idea of warming an engine but i am saying even if I let it sit for half an hour and drive it a couple miles it still occurs if its really cold outside.
