WONT IDLE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDELBLAZ, Mar 2, 2002.
  1. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    i just bought a new 74 blazer with a 350 and a manual trans
    and it wont idle the engine is stock it runs well but when you stop it just dies if you dont feather the gas i dont think its a vac leak but it may be the wrong carb and the electric choke is not hooked up any help please
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    First hook the choke up to a 12v ing. source
    I just did mine to the fuse panel.
    Is it stopping when warming up or at driving
  3. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    We really need more info. Does if act different when the engine is hot or cold? Could be as simple as the idle being set to low.
    87 V1500 305 TBI 208/465 4" 35"procomp mt Dana 44/12 bolt
  4. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    What kind of carb? Had same situation with a carter
    IT'S MOSTLY MAUI WAUI.... BUT IT'S GOT SOME LABRADOR IN IT
  5. JDELBLAZ
    140
    STAMFORD C.T
    the carb is a qjet and it does this hot or cold
  6. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    If you don't have a vac leak and it won't idle when warm--unless the carb is totally out of wack, then I would guess the idle is just set too low.
  7. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    I'd say vacuum leak. try and idle carb. you'll probably have to go way high with it. If it stays running at that point, then idle it back down . IF it dies I'd check for a leak between the top of the carb and the main body. Bet some one had their hands in it and didn't replace the gasket.
  8. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    I would also say to set the idle spead to about 650-750 if ya have a tach
    If it holds idles still replace all the vac lines (not that hard and cheap)
    After that start the motor and with it idling step on the brake and see if the rpms go up if so replace the carb base gasket
    Just my 2 cent's mike
