wont quit dying
Discussion in 'The Garage' started by chvymudin3388, Jan 4, 2006.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    itll be idling and it will die or running down the road and itll die replaced coil it quit for about 1 month and a half
    then i changed the cap module pick up coil stop for about another month or so whats wrong any body else ever have this problem. any one know how to fix it?
    :confused: :( :confused:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Mine was doing the same thing. Figured out that the main shaft hads lost most all of the magnetism.
    If you pull the distro and spin the main shaft you should feel a little pull every time a point gets in-line with one of the prongs of the reluctor
  3. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    k sry but wat exactly is that and where, magnetism of what? i dont tihnk mines has a magnet
  4. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    tonight it died and i couldnt get it back started i got to go back to school monday guys come on yall give me ideas plz i beg yall give me ne help yall can thanx
  5. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i dnt undstnd ewe
  6. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    it keeps stalling wether im driving or sitting in park
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok, thanks, is the fuel system working perfectly? It might be ignition, fuel, or wiring. I'll look into it a bit and see if i can figure anything else out
  8. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    while like i said in my first post it starte dout as it not wanting to start once so i wiggled my coil connections wired then pulled them out and plugged them back in and it started (didnt work tonight did work all the other times) then its got worse so i replaced the coil fixed it for a bout a month or so then i changed the pickup coil got even worse so i replaced cap coil again and module ran for another month or soand i am where i am wich is up at 12:37 a.m. trying to find out wats wrong so i can make it to school monday or tomorrow
  9. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    ok this morning in the light i noticed i unhooked the coil wire from the top of the distributor but that still didnt let it start :( unplugged the coill pack from the distributor harness it started right back up its an 87 so it has tbi the injectors are shooting the whole time so i dont know wats wrong cause after i let idle i threw it in reverse and it died on me unplugged it and plugged it back in and its started right back. im really confused come on guys i got only hours till i got to get it to get me to school:confused:
  10. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    TTT I cant help, but i hope someone else can
  11. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    thanx ne way i hope someone can to i cant figure it out im tired of buying ignition parts :( :( :(
