Won't shift out of Park????
Discussion in 'The Garage' started by K5Glazier, Jan 8, 2004.
  1. K5Glazier
    K5Glazier 1/2 ton status
    May 29, 2003
    220
    Chandler, Az.
    Won\'t shift out of Park????
    Here's my problem. Truck is locked in "Park". It started a couple of weeks ago. Once in a while, I would have to stand on the brakes for the shifter to release. Now it's locked in. Any ideas? Truck is a '95 (2500) ext. cab, 5.7, 4 speed automatic. /forums/images/graemlins/1zhelp.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: Won\'t shift out of Park????
    that would have a "Step on brake to shift from park" correct?
    if it does then probably the brake switch or the soliniod is bad. i they shoudl be under the dash.
    that is all i can help with
  3. K5Glazier
    May 29, 2003
    220
    Chandler, Az.
    Yes, that is a step on brake to shift. Do you know if the brake switch and the solinoid are close to one another? Took a look under there, kind of had to feel around, all I found was a multi wire plug connected to a white plastic housing hooked to the brake pedal rod.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. noJeepshere
    noJeepshere I Drive Trains! Premium Member
    Jan 2, 2003
    8,595
    768
    City of Sand, UT
    one trick i discovered on my 98 sub is that when you turn it to ON, (not RUN) you can shift out of park with out pressing the brake. if it does, your solenoid is bad. if not, well your stuck.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i don't know anything else about these
  6. K5Glazier
    May 29, 2003
    220
    Chandler, Az.
    Hey Riley- /forums/images/graemlins/thumb.gif
    It does shift when the key is on. Thanks for the tip. Hope theres not alot of bullshit to replace the solenoid.
    Joe
  7. noJeepshere
    Jan 2, 2003
    8,595
    768
    City of Sand, UT
    no problem Joe. good luck getting it fixed. /forums/images/graemlins/thumb.gif
    CHEVYs rule, but GMCs are better
    /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
