won't srart
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by win717, Jul 20, 2003.
  1. win717
    win717 Registered Member
    Mar 8, 2003
    60
    PA
    won\'t srart
    Hi again,I wanted to know where to start,My 1989 blazer won't turn over..i drove to the store came home then went to go away and nothing..won't even turn over..i changed battery and nothing I turned on the head lights and hit the key and the lights don't dim..but the radio comes on and when i hit the key it stops..not sure to look at the starter ???or if there anyway to check it..i keeped all the turmols..shock the battery wire....nothing where should i start?
    Rich
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: won\'t srart
    try jumping the terminals on the starter if it turns over your solenoid is bad
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Re: won\'t srart
    What kind of shape is your negative battery cable in? I had a truck with a bad cable and did the same thing. Make sure you have a good ground.
    Kris
  4. flyndragons
    flyndragons Registered Member
    May 28, 2002
    18
    Finally back in the US!
    Re: won\'t srart
    Do you have a quick disconnect on your starter? I fried a plug in mine and the lights wouldnt even come on. That was a quick fix though.......after a week and a half of trouble shooting. Take a circuit tester and check the leads on the starter.
    Then again it could be your igniton switch. Not the lock but the switch on the inside of the dash.
