Wont start after sitting overnight?
Discussion in '1982-Present GM Diesel' started by dhdescender, Nov 1, 2003.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Im having a problem in the mornings when I go to start my truck up, it seems like the fuel is draining back into the tank and my batteries arnt strong enough to crank long enough to get the fuel up. Where would be the best place to look for the leak? Also I heard of people putting electric fuel pumps in the frame rail so solve the problem? Any helps appreciated.
    Jordan
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Mine has the same symtoms when I dont use the block heater.
  3. dhdescender
    Aug 10, 2002
    628
    ok, Ill try plugging it in tonight, its be right around freezing here lately.
    Jordan
  4. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    that what i have done and fixed my problem sometimes i gotta bleed the filter valve but thzts only after sitting for a week or more + i am so paraaanoid i even have a second 1 in the fram rail on a switch if the first one goes out /forums/images/graemlins/crazy.gif
    R
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Sounds like you've got 1 of two problems:
    1: The diaphragm in your mech. fuel pump is allowing fuel to drain back. If that's the case a new lift pump is in order.
    2: There's an air leak in your fuel system somewhere. Take a close look at all your fuel lines under the hood and check for small cracks or splits. I had a similar problem a while back and it ended up being a split line beneath a hose clamp.
    Plugging in the truck should help quite a bit. My 83 is really cranky to start at temps below 2' Celcius. /forums/images/graemlins/tongue.gif
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Sounds like a GP problem to me. I installed the AC 60G GP's and the stock controller wouldn't light em up long enough when it was really cold. I converted to manual contol and it fires up at -2 C without having to plug it in with relative ease. Approx 12 seconds of glow, 3/4 throttle and about 4 seconds of cranking.
    My starter is on the way out though...or it would prbably start easier. My cranking speed is only borderline IMO.
    Rene
  7. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    [/ QUOTE ] /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif I need to get some 60s
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    My 6.2L had a small air leak in the filter base. It was never fixed, and the previous owner went through several starters as a result. After I fixed the leak, it was still a bear to start. Finally changed out the starter (which still appeared new) and it made all the difference. Starts immediately - even when cold. Cranking speed was up at least 50% with the new starter. /forums/images/graemlins/thumb.gif
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    One of the best mods I've made...that and the manual controller. /forums/images/graemlins/thumb.gif
    Rene
  10. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    I have the manual controller, but have yet to get the 60s, soon though as soon as I figure my oil issue out.
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Now I see why I like my Perkins diesel more than my 6.2
    No GP's, no block heater, one battery and a huge ass starter, and it starts like it was just driven even in -5 Celsius so far, and it starts in a split second.
    If it ever takes more than one second then I check for air and I noticed it sometimes gets air when the tank is below half, but otherwise never have problems.
    I haven't started my 6.2 for more than a year now but I guess I will do some preventive maintenance before I do so I don't have any of those issues.
    I will: put G60's
    Put a manual controler
    Change all the soft lines.
    Change Filters and make sure there is no leaks and then hope the lift pump is good if not then maybe change that and rebuild my injection pump and be good for a couple of years.
    Meanwhile my Perkins is just great.
    /forums/images/graemlins/rotfl.gif
