Wont start need help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tuskadero, May 21, 2001.
  1. Tuskadero
    Tuskadero Registered Member
    Jul 14, 2000
    91
    Southern California
    Hello everyone,
    When I woke up yesterday I went to star up my Blazer and nothing happened. She doesnt turn over at all. The first time I tried to turn it over there was a little clicking and than it stoped. I popped the hood and looked at all my connectins they looked good. I also tried to jump start it for the hell of it even though I new it probably wasnt that since I just put in a new battery a few months ago. Does anyone have ideas what they think it could be? Maybe the starter? Thanks, Heather
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Do any of your interior lights come on? How old it the altenator? I would have the battery tested and if it shows low, your altenator might be bad. Or (if you can) you could go where you bought the battery and tell them to defect it and give you a new one and if it starts, watch your guage. See if it reads low while it's running. If it does, your altenator is bad.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    First of all, a new battery doesn't mean a good battery. I've had batteries that refused to hold a charge within a week of buying it. I would get it tested.
    Otherwise, It sure sounds like you left your lights on or something. The clicking normally happens just before you fully run out of juice. And, just in case you didn't know this, a fully discharged battery can take a few minutes to boost. Try hooking up your booster cables and let them sit for a a few minutes before turning the key.................
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  4. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Ya, that's how if you go and have them defect the battery that will most likely weed out the problem if you got a bad battery, but then after you install the new battery, make sure to watch the guage (the one for volts...don't remember the name of it right now) in your truck to see if it reads low while it's running, and if it does, then your alternator is prolly bad.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    That gauge for volts is called a voltmeter.
    Make sure the connections to the battery, the block and the starter are tight. Then let the jump vehicle sit and charge you for 10 or 15 minutes, at least and leave it connected while you're trying to start it.
    Here's one way to check for a dead battery. Hook up a jump vehicle for a couple of minutes and turn on your headlights. then disconnect the jumper cables and watch the headlights. If they dim a lot, then the battery is bad. When it gets like this, it is even hard to jumpstart sometimes.
    To test the alternator just see if it keeps your volts above 13 while you drive.
    <font color=green>"I don't have the brains for business. I want to go into politics" -Mao Xinyu </font color=green>
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Make sure your battery connections are clean and tight.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  7. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    try all what was said and also see if the neg. battery cable is secured tight on the frame or on the alternator brace. where ever yours hooks to. If must have a good ground maybe the bolt came loose. goodluck
    whats a 4 letter word for farm wagon? (ford) [​IMG]
  8. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I had something weird like this happen too. I was leaving my friends house late one night, and tried to start the truck. I turn the key, and the thing just clicks once and nothing happens (lights on and all at this time). so I try it again, and it starts workin. I still dunno what the heck that was to this day.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
  9. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    your battery connections may look good, but check them to make sure they are tight. mine had done that twice this past wek. both times i try to move my battery cables and they were hard to move, but the neg moved alittle bit. and both times the truck started right up.
    '85 Jimmy in Jax, Fl
  10. maxq15
    maxq15 Registered Member
    May 16, 2001
    44
    Miami, Florida
    I just went through something similar with my '87. It had been showing low voltage on the gauge (8.5 to 10 volts) for the past several weeks and slow to turn over when I tried to start it. I assumed that since the battery was new and tested good, that it was a bad alternator. I pulled the alternator and had it tested. It was bad so I replaced it. The problem was still there. I then replaced the starter and the positive battery cable. Upon inspection I found that the connection of the battery cable at the starter showed signs of corrosion and wear. After replacement it starts fine and shows 14 volts as normal. You may want to look in that direction, Heather
    KP
  11. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    A bad starter could cause this. The one in my S-10 had a loose post on the solenoid. (sp) It kept it from starting. Just clicks. Tried the jumpstart thing and everything else before replacing it.
    Just a thought,
    P.S. Make sure you have the auto parts store test the new starter before you leave the place. I have seen 3 bad ones in 2 years. Two were in the store, can you guess where the one was??
    John
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '84 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allsion Auto
