Wont start when warm
Discussion in '1982-Present GM Diesel' started by DOCKAWI650, Jun 6, 2003.
  1. DOCKAWI650
    DOCKAWI650 Registered Member
    Sep 29, 2002
    61
    Gboro, NC
    I have an 82 blazer with the 6.2 diesel. It runs great, but when i try to crank it after its been driven for a while it will just turn over and doesnt seem to want to start. any thoughts??? /forums/images/graemlins/k5.gif
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Just a wild-ass-guess, but maybe the injection pump is starting to go. When the injection pump gets heat soaked after sitting the fuel thins. High mileage pumps start having problems building "pop off" pressure with real thin fuel. To test, some folks add a quart of ATF to the fuel to thicken it. If starting improves a new pump is in your future. /forums/images/graemlins/wink.gif
  3. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    Seems to me that you and ronny.f could have the same problem.I use 15-40 engine oil 3 percents in my fuel just because it´s cheap, they say that two stroke oil is the best additive to lubricant the injectors and pump.I´m not sure but it works for both of my truck´s(6,2). /forums/images/graemlins/crazy.gif
  4. DOCKAWI650
    Sep 29, 2002
    61
    Gboro, NC
    I was thinking the injector pump but was hoping it wasnt because im a little low on money..
  5. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I think you should try to have some motor oil blended in the fuel.And maybe it will help to get a switch to the cold start thing on the injection pump /forums/images/graemlins/confused.gif.Some of my freinds has that to cool the pump I think it flushes in fresh cold fuel to the pump then it will get the pressure up so it will start.Seems to work on their trucks.I´m sure someone here has tried that and can explain it more. /forums/images/graemlins/cool.gif
  6. DOCKAWI650
    Sep 29, 2002
    61
    Gboro, NC
    how much oil would i put in it?? thanks
  7. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    The first thing to do is check that your oil mixes with your fuel.I have 4 percents of oil in my fuel more will just make more smoke.Tried 10 percents once for curiosity and my oilburner ran really well but you could easilly see were I went. /forums/images/graemlins/crazy.gif
  8. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    OLD ON THERE PARTNER!!!!!!!!! Before you go and mix anything with your fuel!!!!!!!!!!!!!!!!! Try this! We have this problem weekly in the army with the H1s! Go out and drive your truck till it gets really hot! Normal operating tempature! Once you get it there, go back to your driveway and turn it off.... Wait about 5 minutes and try and start, if it fails to start like you're saying, pop the hood and take your garden hose out.... run cold water over the injector pump for about 1-2 minutes with the engine off obviously! Once you do that, jumpin the truck and crack like you would normally.... The truck should fire right up! If this works, what's happening is the shutoff solenoid in the injector pump is starting to fail! It's getting so hot that it's sticking in the off position and not throwing back to the run position! All you need to do is replace that top cap on the injector pump! It has the solinoids in it, 3 screws and pay attention to how the throw arm slides in! replace it and you're good to go! There is no reasona to replace the whole pump, it's a pain in the butt and unnecessary! /forums/images/graemlins/thumb.gif
  9. DOCKAWI650
    Sep 29, 2002
    61
    Gboro, NC
    Thanks for all the replies....I will try all of the advice until something works out for me...thanks again /forums/images/graemlins/thumb.gif
  10. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Thats a hell of a good tip. I had no idea that the shutoff solenoid could cause a warm engine no start condition.
  11. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    and where would one locate just the top cap?
    thanks,
    Jerry
  12. BlueBlazer
    Feb 15, 2001
    1,940
    Its right on top of the pump.
  13. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    yeah, i meant where would i be able to purchase just the top cap /forums/images/graemlins/thinking.gif sorry for the confusion.
    thanks,
    Jerry
  14. BlueBlazer
    Feb 15, 2001
    1,940
    Any diesel injection shop can get it for you.
  15. DOCKAWI650
    Sep 29, 2002
    61
    Gboro, NC
    Yeah, i checked advanved, pep boys, and autozone and none of them had it...do you think napa or carquest might?? i don know of any diesel shops..thanks
  16. Batmanjr
    Mar 23, 2001
    1,537
    I haven't had to search one down for my Blazer yet, but being as I work on Hummers all day long, This is a common problem! Please take note! When you remove the top cap from the injector pump, please take special notes on how the solinoid is ingaged with the injector pump!!!!!! If you don't put the solinoid in right, your engine has a high chance of running away on you! The solinoid won't be able to disingage the fuel and you will have no way to kill the engine unless you can starve the air, or cut the fuel hose!!!!!! And it's no fun trying to kill a 5000 RPm Diesel!!!! A co worker failed to do this right just yesterday and I was forced to cut the fuel line after trying to starve it from air! So by all means please use this tip wisely, but enjoy it! /forums/images/graemlins/thumb.gif
  17. DOCKAWI650
    Sep 29, 2002
    61
    Gboro, NC
    how would you prevent the engine from going off on you like that? what would be the putting it back in the right way? /forums/images/graemlins/thinking.gif
  18. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    sounds like I have the same problem you do
    Well I do the same thing the 1 guy sugested i have a swich going to the cold advance electrical terminal on the injector pump off is normal and i switch it on when ever needed then when it starts i switch it off again
    works GREAT !!!! 4 me
    pm me if ya want my phone nu and ill tell ya how I hooked mine up over the phone
    Randy
