won't start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by amm888, Dec 14, 2002.
  1. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    won\'t start
    My battery is dead...should i be able to jump my truck ('76 v8) with my '91 camry...it turns slowly, but won't start when i try to jump it...
    thanks
    alex
  2. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    Re: won\'t start
    Check your connections, Go right from the camry's battery with the car running to the Positive and the negative to a good ground on the engine block, like the alternator bracket.
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Re: won\'t start
    I donno if the camry battery will push the v-8 starter or not.. only one way to find out though give it a try... /forums/images/graemlins/eek.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: won\'t start
    What he said, plus, rev the camary up a few 100 rpm's and leave it there for a couple minutes while jump starting.
  5. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    Re: won\'t start
    sorry - i wasn't clear - i have tried to jump it with the camry and it wont work. i've also tried to jump it with my friend's explorer (v8) - didn't work...just turns over real slow.
    does this sound like simply a dead battery? my friend thinks it's an alternator...
    thanks for the suggestions...
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: won\'t start
    sounds like a roached battery to me
  7. Blazerfun
    Blazerfun Registered Member
    Dec 9, 2002
    11
    Monterey, TN.
    Re: won\'t start
    If the battery has fused a couple of cells it will not jump start. Sounds like its toast!
  8. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    Re: won\'t start
    thanks for the help guys - i didn't realize you couldn't jump if the battery was too bad off - i'll take it down to autozone tomorrow and have it checked
  9. Grim-Reaper
    7,385
    Atlanta
    Re: won\'t start
    Yep a battery can be so fried that it won't jump.
    We had one go in my wifes old car like that. She fires up the car goes and drops the oldest at Day care. Came out and car was so dead no lights at all and wouldn't jump.
    I have been having good luck with the Durlast batteires from the Zone. My 75 sits some times for a week or longer and never had an aounce of trucble turnning over the truck in almost 4 years no matter how cold and how long it sat.
