Wont stay in 3rd
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stock93, Dec 13, 2004.
  1. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    I have an 83 with 4 speed manual trans. I'm pretty sure its the muncie version. Its jumping out of 3rd gear under load and when going from load to coasting. If I hold it in it will stay in gear. When it pops out of 3rd if I dont take the shifter to neutral before trying to put it back in gear it will grind. Any ideas what this would be? shift forks? syncros? Can I reach them through the cover on the side of the trans front left.
    John
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I do not mean this in a bad way but search this subject . There is a whole bunch of great info on that problem .
    It is very common and skip third gear until you can make repairs.
    Tom
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Shift fork was the fix for me.
  4. stock93
    Feb 18, 2004
    68
    Huntsville, AL
    I did search. I didnt find much on it. Maybe I should be typing in a different phrase. My main question was if its the shift forks can I reach them through the side cover?
    John
  5. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    The side PTO covers will not let you get at the forks.
    You"ll need to remove the top cover - just as a note - the shifter needs to be in reverse to take the cover off.
    HTH , Tom
  6. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    If I knew anything about computers I would seach and post up stuff for you but I absolutely suck at computer stuff - I am doing good to post a reply in a thread . It's a good thing I know more about mechanical stuff than the internet .......
    Tom
  7. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
  8. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Look no farther - the article that "Jiminycricket" has brought up all the info you need in it . It addresses the three main problems and the solututions.
    Tom
  9. BlueBlazer
    Feb 15, 2001
    1,940
    All that stuff is a waste of money IMO. They do not even mention worn forks as a problem, which worries me since they are supposedly experts.
