Woo Hoo! It has closed chambered heads.
Discussion in 'The Garage' started by mountainexplorer, Jul 1, 2004.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    The supposed 402BB in this truck I got has closed chamber heads.
    In search of the mystery noises, I pulled a valve cover, finding out that this is the grungiest motor I have ever seen. After some scraping, I got the casting number.
    3917215 which according to Mortec are '67-'68 Oval port, closed chamber 396 or 427 heads.
    The motor is still running like garbage, has a bad miss and deathly rattle, but after retarding the timing back closer to where it should be, I was able to powerbrake the truck (a dually rear crew cab with a utility box) in my driveway. /forums/images/graemlins/grin.gif
    Still pings some, but if this motor is say a higher compression motor, and I have very low octane fuel in it, I suppose it still will.
  2. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    nice score!!! Keep us posted.
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i run those on my 396 with a solid cam. good head.. nice score, dont see them around much anymore...
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i believe alot of the 396/402's came w/ closed chamber heads, the rest ive ever seen had the semi-closed(or is it semi-open) heads.
