WooHoo!! Just won a set of H2 New-TakeOff Tires/Wheels -UPDATED/PICS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73k5blazer, Feb 23, 2003.
  1. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Just won a set of H2 Ties/Wheels, brand new take off's, from eBay. All I gotta do is go get 'em 1hour away....
    The 35" BFG is perfect because I didn't want a 12.5 wide tire, too wide for me, I like thinner. Nice OEM 17" wheel, already mounted and balanced.
    I'm sure I'll have to modify the center caps, and mabey find the right lugs to fit on my studs, either that or swap to the metric studs so the factory lugs will fit.
    Has anyone put these H2 wheels on their K5/Chevy fullsize????
    There are good deals on these things all over eBay, $700-800 usally plus shipping, but I just waited for a set close enough to where I could pick them up.
    Perfect for my project K5. I just hope they don't rot before I get the truck done....
    BlazerMan
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: WooHoo!! Just won a set of H2 New-TakeOff Tires/Wheels for $610!!!
    Are these going under your '73? Let us know how the extra deep offset of those H2 wheels work out. /forums/images/graemlins/cool.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Pics.
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Are you looking for me to post pics or are there pics on that link in your post. I can't find any pictures of trucks on the website, if they are supposed to be there??
    I havn't picked the T/W up yet, I can post some pics as soon as I get 'em and mount 'em up, probably a week or two though...
    Hey, by the way, how much difference is there in offset on the H2 Wheels compared to stock ones???
    Blazerman
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The H2 uses the undercarriage from an IFS Suburban. If you look at the center section of the wheel on GM's IFS trucks, you'll see that it is nearly flush with the outer edge of the wheel. Wheels from the earlier solid front axle trucks have the center section tucked way back inside the wheel. I hope there's clearance behind the wheel for the deep offset, espcially up front.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Just wanted to see what ya got.
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Ok, from some quick research a standard H2 rim has 5" of backspacing and a standard 73-87 chevy truck 8-lug rim has 4-4.25" of backspacing (I found 5 places, 3 said 4", 2 said 4.25 or 4 depending on certain wheel options??).
    So, 3/4" to 1" doesn't sound like that much?? With a 17" wheel, I shouldn't have any caliper griding to do like I did with my standard 15" 8-lug rims.
    Anyone here running wheels with 5" backspacing?? If so, how does the truck handle??
    Are wheel spacers on option, I've heard they are generally a bad idea, especially on trucks, I generally see/hear of them on little rice burners....
    BlazerMan
  8. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I run these with 5" backspacing. They are 16x10 and do clear the steering of my ten bolt (barely). I haven't test fitted them on my Dana 60 yet. The truck handles fine and looks good. Your rims/tires will work nicely. The bigger offset will help the 35's clear the fenders too.
    Here's a bad picture of mine
  9. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    will the center hole clear the old style hub????
  10. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I'll find out tommorow, when I pick them up. I'm pretty sure it will. The cap will need modified, I'm sure espcially on the front where it will need a hole for the lockout hub, shouldn't be a problem though....
    My bigger concern is the backspacing, but from other posts, it seems the 5" will be OK...we'll see....if they don't work out, I'll just re-sell them...
    BlazerMan
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Re: WooHoo!! Just won a set of H2 New-TakeOff Tires/Wheels UPDATED/PICS
    Ok. Picked up the Tires/Wheels. I'm really not ready for them yet, but tossed two on just to see how they fit/look.
    Tooks some quick pics;
    Looks like I got an interference problem with the tie-rod end dust boot. (Yes the wheel weight clears as it comes around, barley!) Other than that, I can turn lock to lock with plenty of room to spare. There are also no problems on the rear. I'll have to get the proper lugs, the ones that came with the wheels are metric, and the lugs I have that fit my all new studs (english) don't have deep enough shoulders for proper fit. Other than that, it looks as though I'm good to go!
    Probably a wee bit of front fender trimmin' as well, but that was half expected anyhow.
    All in all, A Smokin' deal for 4 brand new wheels, 4 brand new 35 inchers, already mounted and balanced at $610!!!
  12. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Damn! Those look great, even with all that backspacing!
  13. CK5
    May 19, 1999
    21,627
    704
    CO
    What's up with that front fender? /forums/images/graemlins/shocked.gif
  14. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It's fiberglass, like the rest of the body (except doors & gate). There are still mold lines in it that need to be sanded down. It's all one piece, so it's split on the angle there behind the wheel, so it tilts forward. The lower rear pieces are fixed to the cab.
  15. CK5
    May 19, 1999
    21,627
    704
    CO
    Ahh, that's what I thought (fiberglass) just haven't seen one like that.
  16. new2k5
    new2k5 1/2 ton status
    Dec 16, 2002
    128
    south eastern PA
    argh that really burns me up. i had asked about these wheels tires awhile ago and everyone told me they wouldn't work. /forums/images/graemlins/angryfire.gif so i went with some 16.5. /forums/images/graemlins/frown.gif
    they look great on your truck! /forums/images/graemlins/thumb.gif keep us up to date on how the tir road interfeerence effects things. also could you post a pic of the hub coming through. i think i am going to get set i just wish i would have done it right off the bat.
  17. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Here you go..
  18. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    Do you have a plan for that TRE?
  19. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Not yet. Perhaps a 1/16" spacer??
  20. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    might work, just watch the thread engagement
