Woops!? Are 12 bolt and 10 bolt 30 spline axles the same??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smack, Oct 11, 2002.
  1. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Awhile back I replaced my 30 spline 10 bolt rear with a 12 bolt and just today I was browsing the new LMC catalog and noticed that they list the axle lengths as different. 12 bolt is 31-9/32 and 10 bolt is 31-5/16.
    I haven't noticed a problem but should I be concerned since I used one of the 10 bolt axles in the 12 bolt???
    smack
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I don't think 1/32" is enough to worry about, and if you have been running it that way for awhile with no problems then it should be ok.
  3. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    WOW, that make a world of differnce to me! i have been looking ALL over for a Spare 30 spline 10 bolt, i am sure i can find a spare 12 bolt in a yard some place!
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The difference is in the length of the little piece of shaft that sticks out past the c-clip. You can use a 12 bolt shaft in a 30 spline 10 bolt by grinding a little bit off of the end of the shaft. If you don't grind it off, you will not be able to get the cross pin back in the carrier. I would not use a 10 bolt shaft in a 12 bolt, since there would be excessive end play, and the c-clip could fall out.
  5. smack
    Feb 24, 2000
    277
    Colorado
    Ah, see that's the info I was looking for. But now you've gotten me paranoid!!
    oh well
    smack
  6. Blazer1970
    1,600
    Old Mission, MI
    Hey, worst case your axle falls out as you are going down the road. No biggie! I am not really sure if the c-clip could fall out or not, but it sure seems like it could from the amount I had to grind off the end of the 12 bolt shaft when I put it in my 10 bolt.
