Working on square Driveshafts..... Have questions.....
Discussion in 'The Garage' started by Batmanjr, Aug 21, 2003.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Alright, I ordered my yokes from Jesse and they're here, I just got back from vacation and they were waiting on me! Thanks Jess! I stopped in Waco on the way home and picked up the tubing... 6ft of 2.5", and 6ft of 2", all .25 wall and only cost me $32! /forums/images/graemlins/thumb.gif 1st question: When I went to slide the 2" in the 2.5", the weld on the inside of the 2.5" kept the 2" from sliding in.... How do I fix this? Do I grind off the first 1" and then ram the rest through? What do you think?! 2nd question: Would you guys weld the 2" tube to the front yoke, or the 2.5" tube to the front yoke? /forums/images/graemlins/thumb.gif Thanks in advance! /forums/images/graemlins/ears.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You should have gotten 2.5" receiver tube or DOM square. It won't have a seam. You can cut it out, or grind a groove into the 2" piece. There is a recent thread on PBB where a guy talks about this. I got 2.5" DOM for mine.
    Put the big side on top, otherwise it will hold water.
  3. Batmanjr
    Mar 23, 2001
    1,537
    What are the technical differences in the DOM tubing rather than what I have... This is the only stuff I could find anywhere locally.... I tried 3 metal shops before I went to a metal supply house in Waco.... Should I call and see if they have DOM and take this back? THanks! /forums/images/graemlins/thumb.gif
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    DOM (drawn over mandrel) tubing i believe is not seam welded like what you have..i might be wrong...
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You most likely picked up ASTM A 500 Grade B Tubing. Tensile strength 58,000 min, Yield Strength 46,000 min. It is welded together with the weld seam on the inside of the tube making it more difficult to use as the outer slip tube.
    DOM is Drawn Over Mandrel [ QUOTE ]
    An Electric Welded Tube with all weld flash removed. Tested for weld soundness, drawn over a mandrel and retested. This product is superior in finish and wall uniformity to seamless tubing.
    However I have never heard of DOM square tube and can't find it in any of my catalogs. The last fab shop I worked for could get a 2.53" x 1/4" wall tube in the ASTM A 500 Grade B. It works great for slip tube /forums/images/graemlins/thumb.gif
    Yes /forums/images/graemlins/thumb.gif
  6. Catwoman
    Catwoman Newbie
    Mar 9, 2003
    Copperas Cove, Tx
    if i picked up ASTM A 500 GRADE B tubing and that's all you found in your catalogs, is there a such thing as dome square tubing? where do y'all suggest i get it if i can't find it locally? /forums/images/graemlins/ears.gif
  7. Batmanjr
    Mar 23, 2001
    1,537
    By the way, that's my wife responding for me! THanks Guys! /forums/images/graemlins/thumb.gif
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    DOM is what they called it at the local yard. Much like round DOM, it has tighter internal tollerances according to their spec sheet. However, unlike round DOM, it has a hint of a ridge inside, though you can see where the inner weld ridge was sheared/flattened along the entire 20' length. This is not just cut out on the end like a piece of "receiver tube" I bought from Q-S (local hith manufacturer) to do my floor mount bender/anvil/table/vise/whatever mount.
    There is very little slop in my shaft and the inner weld has just enough bite to hang a finger nail on if you try. There is only one shop in Phoenix (to my knowledge) that sells this stuff. A guy on PBB told me about them. Whatever it is, it makes nice square shafts.
  9. Batmanjr
    Mar 23, 2001
    1,537
    I read about that stuff, it's not technically DOM, but as close as you can get to it! Basically they take what I have and drag it over a mandrel and heat it up to knock the weld off the inside... This does two things, one cleans the inside and two hardens the material to make it stronger... This is what I read... I just can't find it locally! I have a lead down in Austin and em going down tomorrow... Hopefully I will find something there! Thanks guys, I've decided to keep both tubings, never hurts to have extra metal laying around, and get some reciever hitch tubing to use with the 2" stuff... Thanks! /forums/images/graemlins/thumb.gif
  10. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    let me know where you get it. I will be making some spare shafts out of the same stuff.
  11. Batmanjr
    Mar 23, 2001
    1,537
    So far I found this place, but kind of pricey!
    trail hitch square stock
    Other than that, Charles and I are going to swing into JK Customs in Hutto tomorrow and see what we find... I'm also coming down with a armament of steel supply shops in and around Austin and some trailer places! THat's the goal! If it falls through by noon, I plane on just biting the bullet and buying it over the net so I can have these done by next weekend! /forums/images/graemlins/thumb.gif
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I just made another shaft and took some pics since you guys are planning to make one. Take it for what it's worth (not much).
    Blurry, but you can see the yoke where I notched it for the 2" tube to fit inside. I fit the tube in, square the tube to the table, use a depth gauge to make sure the tube is in the center of the yoke checking all 4 sides. And measure from the table up to the turned ridge on all sides. I keep grinding and fitting till it is as close as humanly possible with my primitive tools. Once square, I tack 2 opposite corners and recheck. Then I make the first pass welding *inside* the yoke bridging to the 2" tube. Then I slide a 1" collar of 2.5" over the small tube and weld it in just over flush. After cooling, I grind it smooth in hopes of keeping the balance somewhere close. Big side is much the same, except I make a 2" x 1" insert piece to fit in the 2.5" and the yoke cup.
    Here are some pics of the completed shaft with the unmolested yokes for comparison
  13. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    when I called I asked for tubing for a hitch and he said 2" and 2.5" (reciever) tube cause there is no seam so it slides together. It was way cheap too. both are .250" wall.
    I'm thinking of doing a rear one too.
    -Jeremy
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Very nice work Russ. /forums/images/graemlins/pimp1.gif /forums/images/graemlins/thumb.gif
    What size and wall thickness conventional round tube are those yokes for?
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    You can take your 2.5" tube to a machine shop and have the seam swedged (sp) out. Basically they shove a ram through the tube and it removes the flash. I don't know what this costs but it might be worth looking into since you already have the tubing.
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Thanks. Those are for 3" tube.
  17. Batmanjr
    Mar 23, 2001
    1,537
    Thanks for the pics Baddog! Looks sweet! Never thought about using 2" of 2.5 on the bottom to help weld in the 2"! That's a great idea! I've done some research.... This is what I found out.... I bout two combo bars from a hitch place in Austin this weekend and thought I was set... I went to slide the 2" inside and it felt like throwing a hotdog down a hallway!!!!!! It was looser that crap! So I started looking at the combo bars and they were only 3/16th wall and cost me $90 for the two of them! So I returned it and went and bout a $5 bastard file at Lowe's! I ground down the seam on the inside of my 2.5" pipe for about 2-3" and slide the 2" inside! Can you say NICE! It was tight, but not binding.... Went in and out like butter but I had NO slop! So I've decided to use what I have, don't know about the ram cutting the seam out, but a 32" piece of tubing is only 16" from end to center, so I'm going to go get to work on grinding this tubing out and using what I've got! I would rather put a little more work in it and have quiet shafts than the slop those reciever bars were going to give me! Might change my mind after 3 hours of gringing, but hey, it's worth a shot! Thanks for all the heads up guys! /forums/images/graemlins/thumb.gif
  18. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Looks like my description of my joints was not so easy to understand. So here is another attempt. I'm not saying this is the only way, or even the best way, it's just how I did mine. Anyone with suggestions would be much appreciated...
  19. Batmanjr
    Mar 23, 2001
    1,537
    Looks great to me! I understood it the first time, Great detailed layout this time! Only thing is I have 2.5" yokes instead of 3", but I'll get them to work! I just notch the opposite of you OR just notch more! I've heard of people cutting the whole thing off and welding to it flat, but I hate that idea! /forums/images/graemlins/thumb.gif
  20. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    OK, dumb question time...
    Why square driveshafts?
