working on tailgate/rear window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MXmastermike, Aug 27, 2002.
  1. MXmastermike
    MXmastermike 1/2 ton status
    Dec 23, 2001
    167
    Columbus, Ohio
    how do i stick the rear window to the metal piece that runs acrossed the bottom of it?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Epoxy or something like it.
  3. MXmastermike
    Dec 23, 2001
    167
    Columbus, Ohio
    how about gasket maker? its all i got
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I used a good, waterproof adhesive. Had to use more than I thought to keep it in there. PITA to not use the right stuff or enough of it, then have the window come out and then have to scrape all the old stuff on and re-do it.
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Go to a glass hose and buy some of that stuff the use to install winshields. Its that black goop that comes in a tube that fits in a caulk gun.
  6. MXmastermike
    Dec 23, 2001
    167
    Columbus, Ohio
    thanks for the replies, i was wondering what that black stuff i was scraping off the window was
  7. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    The piece across the bottom of the glass is called the sash. I wouldn't use the urethane, my friend just tried it on his and it just made a big mess and popped apart. I used RTV on mine and rolled the glass up. I didn't roll the window down for 2 days and it worked like a charm.
  8. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    When I put my tailgate glass in I went to my local chevy dealer and bought the stuff that was originally there. If I remember right, it was a kind of thick, sticky tape that you fold over the bottom of the glass and then you put the glass in the channel. They sold it by the foot, and it was fairly cheap.
  9. dyeager535
    26,980
    Sounds like Butyl Rubber, which is the same stuff they USED to use to hold windshields in. (still used on travel trailers, etc) It doesn't harden, and is sticky as all get out. Comes in a roll like tape, right?
    You can buy it at good hardware stores too, and it is pretty cheap.
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    rtv would be a good bet... and yeah, let it set for as long as u can stand b4 u test it so it sets up really well. 2-3 days oughta do it. I'd leave it a week just cause I'm a geek. /forums/images/icons/tongue.gif
    J
  11. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    5-min epoxy worked wonders for me
