World's biggest trans cooler?
Discussion in 'The Garage' started by K1Orion, Jan 29, 2003.
  1. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    World\'s biggest trans cooler?
    Would this even work? I have removed the a/c equipment from my truck and noticed the condenser is huge. Could you flush it out and hook up the trans cooler lines to it? This is kind of a crazy idea but i figured i'd throw it out there!
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: World\'s biggest trans cooler?
    I'm almost positive that this has been done by more than a few guys. I'm not sure what mods were needed, though.
    One of the Brotherhood will be along shortly to provide better details, I'm sure. In the meantime, I suggest you try using the "search" button located at the top of the page. You'll probably find a lot of info you need........
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It has been done several times. Makes a hell of a cooler. The only trick is in getting the line sizes to hook up.
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I got it to work just fine on my 83. the hard part are he fittings on the condenser, I would have to look but I think I cut both of OE fittings and put on a different deal. I found most everything at NAPA.
    ERIC
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I would reccomend NOT doing it.
    - A air conditioning condenser is in front of the radiator, blocking, or atleast limiting, air flow to the radiator.
    Thats not a huge problem, but why restrict flow to the radiator, if you don't have too. (engine cooling supersedes ALL other cooling demands)
    - The A/C condensor might restrict fluid flow.
    Possibly preventing the trannsmission from reaching it's intended operating line-pressures, which might allow the clutches to slip and wear prematurely.
    - Water will accumulate in in ALL components exposed to out-side air.
    This includes the Engine oil, Diffs, Composite head-lights, and Transmissions. Under "normal" operating conditions, the components will heat up enough to evaporate the water into harmless steam and allowed to escape. Now, if the component (tranny in this case) is not allowed to reach "normal" operating temps, the water will not evaporate and it might cause problems (rust, lubrication concerns, airiation, ect.). A A/C condensor might not allow the tranny to reach operating temps.
    It's ALL-about keeping the component AT operating temps, not ABOVE or BELLOW.
  6. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    I agree with Twiztid. It seems like it would keep things too cool.
  7. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I asked this same question about a year ago when I removed my AC stuff. The consensus was that it would over cool the tranny.. so I didn't do it.
  8. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    If you do it get a thermostat. They sell thermos that will block off the cooler when the tranny isn't up to proper operating temperature.
