Worn out adjustable steering collum?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Feb 4, 2001.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    I have a 88' with a worn out adjustable steering collum.There is extreme sloop, 3 inches all direction at the steering wheel. Are there any fixes out there? Am I looking at replacing it? I have seen only 2 extremes, extremely sloopy or tight. What gives? Thanks guys.
    Displacement, cubes, and did you say you drive a riceburner???
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Glad to see you're still around............didn't sell?
    Your column (believe you mean tilt steering?) probably needs the joint rebuilt. There was a post about that on here recently, but don't remember the specifics. You can get the parts at a dealer and have it done there too.........or send the column out to FlamingRiver or a place like that. Probably easier to have the dealership fix it.......or get the parts and do it yourself (though that job is better left to the dealer).
    Normal thing to wear these joints out since a lot of people use the steering wheel to get into the truck.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i wish i had tilt steering lol
    s.smith 77blazer lookin 4 mud [​IMG]
  4. Here is the fix for the tilt column again !!
    Here is the infamous “GM tilt column loose problem” fix:
    Disconnect the Battery, Tilt the column to the full UP position, Pull the wheel
    Remove the locking plate, the large spring & the bearing cover (This comes off fine, but is a pain in the butt to get back on so I made a tool to put it back on)
    Disconnect the connectors for the turn signal switch, cruise and the "smart" switch
    Remove three screws that hold down the turn signal switch
    Gently pull the switch up and pull out of the housing folding down and hang by harness
    Remove the Ign Key buzzer switch and retainer clip
    There is either a screw on the right side holding in the IGN KEY LOCK or a slot in which you push a tab.
    Remove the screw or push the tab and remove the Ign Lock Cylinder.
    Most of us have been this far before into the tear-down.
    Next there are three or four torx head screws that hold the housing onto the tilt bowl, remove them.
    Return the turn signal switch back into the housing, do not put the screws back. This step is to give you some play in the wiring
    Gently pull up on the housing up and over the steering shaft. Tilting the shaft down will help but it puts the upper ball bearings in danger of popping out. The small cover for the tilt handle, the plastic push piece will all fall out
    There will now be a black bowl exposed. It has the bearings for the short shaft. The Hi Beam actuator rod will be coming through on the left side. There will also be a small rod through the top parallel with the floor. It is the sector shaft for the IGN Switch and has a small gear on the left.
    THIS IS IMPORTANT!! THIS IS THE PART THAT IS SPRUNG LOADED!!
    At the bottom is a small, about the size of a quarter, round silver plug with a square cutout in the center. This is the spring retainer. by tilting the column up most of the load has been removed from the spring. Take a #3 Phillips screw driver, put into the square hole. The object is not to go through this hole but to engage it. Push the plug down/in about 1/8 inch and turn counter-clockwise. There are two ears 180 degrees apart that retain the plug. REMEMBER IT IS SPRING LOADED!! Ease up until there is no load and pull out.
    The next step requires a small puller. I used small screws and vise-grips on one and a small crow bar on the other one !! They are in there pretty tight too !!
    There are two pins 180 degrees apart on the sides of the bowl. These are the tilt pivot pins and they need to be removed. Kent-Moore makes the special puller but I have seen other folks put a small screw in the hole and pull them out with Vise-grips. If the screws break you are hosed! The pins are harden and can't be drilled out if it gets screwed up.
    Once the pins are out put the tilt lever back in. Pull like you want to tilt the column. This releases the pawls from the retainer grooves.
    While holding them released, gently pull the bowl up towards you. The ball bearings are in danger of popping out again as they are disengaged from the races.
    You will notice that the upper shaft is connected to intermediate shaft by a white plastic ball socket. DO NOT BEND THIS TO 90 DEGREES OR IT WILL BECOME DISENGAGED!!
    Slide this to one side and two of four torx head screws will be exposed. I use a ¼” drive ¼” socket on a flex universal to gain access. This eliminates the danger of bending the tilt ball too much.
    If it's real loose tighten one from each side diagonally, That way the mechanism will seat and not bind. I recommend that you put locktite on them !!
    Going back together is just doing it in reverse with some extra steps.
    Reposition the tilt bowl on the shaft, pull back on the lever and slide on. Make sure the pawls engage the retaining grooves. The rods down to both the starter switch and the headlamp dimmer need to be lined up.
    Replace the tilt spring by depressing with a screw driver and turning
    To time the start switch the small snap ring retaining the sector gear, white or black plastic, and gear needs to be removed
    These will not be replaced until after the pivot pins are reset.
    Install these pins with a gasket hammer, SMALL! You may need to jiggle the bowl by actuating the lever disengaging the pawls
    Now time the ign rod rack with the gear and actuate a few times to make sure the Large cutout in the gear for the ACCESSORY position is timed. The rod has a tit that has to go into the racks crescent shaped area. This crescent shaped area allows the rod to be actauted from any tilt position when the key has been turned.
    Slide the turn signal housing down over the bowl, aligning the small tilt lever cover and headlight dimmer actuator. Small daps of grease will help hold this in position while trying to put it all together
    The rest is put together as taken apart.
    The Ign lock cyl goes in before the buzzer switch. The small tab on the lock cyl that actuates this switch needs to be held up in the close position. The IGN key needs to be out of the cyl for this to happen. Small dabs of grease will hold this up during assembly
    Another tip:
    Loosen the two nuts, maybe three that hold the column up to the dash frame. They are either 17mm or 15mm bolt heads. This will give you a little more play in the wiring.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  5. Grim-Reaper
    7,385
    Atlanta
    Re: Here is the fix for the tilt column again !!
    BigBurb:
    Great Post about the repair. Why don't you submit it to Steve and have him post it in the Tech section so that it will be available always and people can be directed to check it first. I did that with the heater core replacement question that always comes up. Few other people are dooing some other tech tips like Ball joints, axle seal replacement etc. Steve will send you a Sticker if he posts it.
    Also Auto Zone will rent you the locking plate compression and installation tool for a $20 Deposit (they sell it for like $10).
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i agree with grim that is a great how to post send it to steve
  7. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    Hey Big Burb. That is an excellent post as that is exactly what I did last Thursday. That rod for the hi beam was a pain in the a$$. My steering column is broken in the area under the hi beam switch so we had to electrical tape the switch so it doesn't move down. Even though you are only tightening up two of four (or three) my column is tight as a nuns; well you know.
    Exellent description.
    Canuck
    Go Wide or Stay @ Home
  8. Canuck
    183
    Excellent description.
    Canuck
