Worn spring?
Discussion in 'The Garage' started by trogdor4x4, Dec 20, 2003.
  1. trogdor4x4
    trogdor4x4 Registered Member
    Dec 15, 2003
    37
    Spring, TX
    I bought my 91 K5 this past August which is my first experience in the 4x4 relm. Is there any way to tell if my stock springs are worn or could last a while longer. /forums/images/graemlins/ears.gif
    Thanks for the replies in advance.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    If they don't sag and look like they are in good shape than I would say they are fine. 91 is pretty late model for worn out springs(IMHO). Try putting a trailer on it, watch how much the back sinks as you crank on the trailer jack. If they bottom out on the overload spring fairly easy with a lighter trailer than thats probably not a good sign. /forums/images/graemlins/crazy.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    of course a k5 would probably not have much for springs stock anyways
    good luck
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    good luck
    [/ QUOTE ]My stock springs aren't too bad, but with a heavy trailer they will sink down a ways /forums/images/graemlins/thinking.gif I have an add a leaf so it helps stiffin them up a little.
  5. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    When your rears sit on the Overloads at all times and your front end still is lower then the rear...Like my springs /forums/images/graemlins/crazy.gif gotta love the pogo-stick action when goin down a bumpy blacktop /forums/images/graemlins/tongue.gif
    Im goin for 2 inch lift spring packs all aroudn this summer
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    good idea! /forums/images/graemlins/eek.gif
  7. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    From July till Novembet it was my daily driver putting 150 miles at least going back and forth to college. Its gonna get to do that again this spring until I have enough saved for the springs. Its rather hard to find a full set of 2 inch springs though. Usually they are just spring front block rear /forums/images/graemlins/crazy.gif
