Worth the change to?
Discussion in 'OffRoad Design' started by GOK5, Mar 8, 2003.
  1. GOK5
    GOK5 Registered Member
    Aug 19, 2002
    23
    wandering aimlessly about
    I am currently running 2" rear blocks and 1.5" superlift front springs on 33's. Does anybody have an opinion if going to 2.5" ORD flip w/ greasable bushings and front 0 rates will have benefits over existing setup? Just looking for any extra articulation over what I have now.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    don't think you will improve articulation mucb ut this will help reduce axle wrap. Be stronger and safer tahn rear blocks as well.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    The shackle flip will soften the ride in the rear quite a bit....it converts you from a "tension style" shackle to a compression style and makes it easier for the spring to "flatten out" and flex.
    The downside is that you will sacrifice load carrying capacity (it's softer now) to get that extra flex. It's always a tradeoff! /forums/images/graemlins/cool.gif
  4. GOK5
    Aug 19, 2002
    23
    Thanx for the info guys
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Load carrying doesn't change very much, the shackle angle is set up to give you a stock type progressive spring rate which is what you would want anyway.
    To answer the original question, you're not going to see a major change in suspension flex, it may work better in other ways but ride and flex will remain very close to what you have now.
